Philips - BV Endura
Mobile C-Arm
Workhorse mobile C-arm for surgical imaging offers vascular functionality with a wide field of view, optimizing workflow. Perfect for general fluoroscopy and vascular specialization, the BV Endura helps users clearly view dynamic images in surgery. Designed to improve workflow, this versatile system has many beneficial characteristics.Perfect for general fluoroscopy and vascular specialization.
FORUMSView All (25)
0Replies15 days ago | IDS Link error in BV Endura R2 Hello, I have a case where randomly the error logging records the following events: W VSI Error 40 (IDS Link status not Ok) Warning IDS Link: # total bit errors detected the ethernet cable ( value of "#" varies on each logging event) I have already checked the ethernet cable but seems ok and I cannot reproduce the failure. Could the DFI-3 cause this kind of problem? any suggestion? Thx in advance Reply |
1Replya year ago | Monoblock Good afternoon,I need quotation for a philips Bv Endura monoblock: 9890-000-61831. Can you quote me it please? Equipment: Philips BV Endura Reply |
0Replies3 years ago | M061 Error I have a BV Endura C-Arm that was shipped here from overseas. I switched the mains power transformer from 100V to 120V. When I boot up the system I an error message ( M061 "Wrong Viewing station connected") on the x-ray station. Has anyone ran into this problem or have a suggestion to match the viewing station? I have Level One IST access. Is a higher IST level needed?Reply |
- Flexible choice between 9” or 12” image intensified
- Extended rotation for vascular projections
- SmartVision imaging technology
- Ultra-compact MobileView Station
- 1K2 imaging – a fully digital imaging chain with advanced noise reduction and 2D edge enhancements for higher image quality
- BodySmart – software that finds, tracks and defines the field of view to anatomy for ‘first shot right’ imaging
- Automatic Shutter Positioning – optimal shutter positioning for the best quality image possible and a clear view of the region of interest
- Automatic contrast/brightness – real-time contrast and brightness control at the touch of a button improves ease-of-use and provides faster control for better image quality
Height | 73.6 in |
Length | 68.9 in |
Weight | 649 lbs C-arm, 463lbs- monitor |
X-ray Generator Power Rating | 3.15 Kw @ 110 kVp |
Image Display | 18 in Dual Monitor |
Motorized Tilting/Pivot Rotation | 360 |
Width | 32.1 in |
