Philips - BV Libra
by Philips
Mobile C-Arm
This lightweight, highly maneuverable fluoroscopy system comes with a 9” image intensifier and loads of important features. Designed to handle all your routine procedures, the BV Libra has one of the best price/performance values of any system in its segment.
FORUMSView All (51)
-eadel43_2205
a year ago
Error uncontroled x-ray, switch system of
Hello everyone, I need some help with a device called Philips C-ARM BV libra.
When I started working on the device the power supply couldn’t reach C-trolley. Then I discovered that there is a problem with the on-off board on mvs.
After I fixed the board the power supply could reach C-trolley but when I try to shoot an error appeared on screen “uncontrolled X-ray, switch system off”.
If anyone could help me with solving this problem I would appreciate it and do you think the on-off 1-broad has anything to do with this problem?
Thank you in advance.
Equipment: Philips C-ARM BV libra
-dio
a year ago
manual service
defaut pedal
Equipment: bv libere
-adell
2 years ago
Service manual & error M208
Hello everyone I need Service manual for Philips BV libra, have error M208. Can anyone help me?.
Equipment: Philips - BV Libra
SERVICE COMPANIESView All Mobile C-Arm Companies
  • Compact, easy-to-steer
  • 9” triple-mode image intensifier
  • BodySmart imaging software
  • Dose saving pulsed fluoro mode
  • Full RIS/HIS compatibility
X-ray Generator Power Rating3.15 Kw @ 110 kVp
Motorized Tilting/Pivot Rotation360 C-Arm
