Fresenius - PT, ST, VS
by Fresenius
Optima VS, Optima PT and Optima ST are volumetric pumps, well suited for all treatment areas. Optima VS, Optima PT and Optima ST offer an extensive range of setting modes to meet all infusion protocols.
-arjulianus
Tue Mar 19 2019
Maintenance code optima vs
I having a problem about infus pump optima vs. i need maintenace code for test unit.Reply
[list]          [*] Flow rate range 1 to 1000 ml/h (1500ml/h Optima ST) in normal mode. 0.1 to 100 ml/h in micro-infusion mode          [*] Flow rate accuracy ± 5% with recommended sets          [*] Volume range 1 to 9999 ml in normal mode. 0.1 to 999.9 ml in micro-infusion mode          [*] Infusion time adjustable from 1 minute to 96 hours          [*] Setting modes flow rate only, flow rate + volume, volume/time, rate + time, ramp up/ramp down, primary/secondary, sequential, bolus, induction/loading dose, micro-infusion          [*] Optima VS: OCS (Occlusivity Check System)          [*] Optima PT/ST: Drop sensor          [*] DPS (Dynamic Pressure System): detection of pressure variations in the line allowing both a faster occlusion detection or a line disconnection detection          [*] Anti-bolus system: automatic bolus reduction at occlusion release          [*] Pressure limit adjustable from 100 to 900 mmHg          [*] RS232 bi-directional connection          [*] Battery life: 5 h 30 in average at 125 ml/h          [/list]
