BINDER - CB
Incubator
The BINDER CB series CO2 incubator is the premium class among the CO2 incubators. It is suitable for all sensitive incubation applications and ensures optimal cell growth. A BINDER CO2 incubator of the CB series is up to even complex cultivation experiments or individual environments.
1Reply2 years ago | Incubator Service manualReply |
- Temperature range: from 4 °C above ambient temperature up to 60 °C
- Humidity range: 90 to 95% RH
- CO‚ control range: 0 to 20 vol.% CO‚
- Tried-and-tested anti-contamination concept with 180 °C hot-air sterilization
- Optimized double-pan humidification system with condensation protection
- CO‚ gas-mixing jet with Venturi effect
- Hot-air sterilizable CO‚ sensor with single-beam infrared technology
- Intuitive touchscreen controllerInternal data recording, can be read out in open format via USB interface
- Fail-safe CO‚ automatic diagnosis system for protecting the pH of cell cultures
- DuoDoor™ system: Unit door and glass door can be opened with one handle
- Tightly sealed inner door made of tempered safety glass
- Lockable door handle
- Perforated shelves, stainless steel
- Troubleshooting system with visual and acoustic alarms
- Computer interface: Ethernet
- Zero-voltage alarm contact
- Units are stackable with stacking adapter optional equipment* Versions with O‚ control range: 0.2 to 20 vol.% O‚ or 10 to 95 vol.% O‚
- Versions with humidity control range: 50 to 95% RH due to active humidification
- Convenient water supply with reusable tubular bags, pre-filled single-liter water bottle, or water container set with a magnetic holder, for versions with active humidification
- Multi-sectional glass doors with special shelves for dividing up the space to accommodate different experiments
- Stacking adapter for secure, space-saving installation
- CO‚ gas tank changer for connecting two gas tanks to one or two incubators
- CO‚ shaker with corrosion-resistant components in a stainless-steel housing
- APT-COM Multi Management Software – for managing, recording, and documenting unit parameters
- Services – a wide range of services to ensure that the unit functions correctly
- Seamless stainless steel inner chamber
- Auto-sterilization with hot air at +180 °C
- Hot air sterilizable CO‚ sensor with single-beam infrared technology
- Double-pane humidification system with condensation protection
- Touchscreen controller with internal data recording via USB interface
