Thermo Scientific - MSC-Advantage
by Thermo Scientific
Conserve energy with Thermo Scientific™ MSC-Advantage™ Class II Biological Safety Cabinets, which combine smart design and extraordinary value with best-in-class energy efficiency, reliability and usability resulting in an overall improvement to operation and maintenance. Units feature 60% less energy consumption and heat output. Cabinets are certified to EN 12469 safety standard.
1ReplyFri May 09 2025 | Error 4 & 5 What might be the problem Reply |
[list] [*] With microprocessor control [*] Large front-panel display (easily visible from seated position) provides constant readout of downflow and inflow velocities and filter usage status [*] Exclusive Performance Factor monitoring system advises when cabinet service is needed [*] Proprietary window opens to 20cm working height, 53.5cm maximum height, easily lowers for interior cleaning [*] Ergonomically angled window is sloped at 10° for better comfort and reduced operator fatigue [*] Unique airflow technology and intelligent motor design dramatically improve energy efficiency, operation and serviceability; provide excellent sample protection [*] SmartPort: T¨UV-approved, safe, clean method for vacuum tubing and cables routing method through the side wall of the biological safety cabinet [/list]
