EPPENDORF - Thermomixer R
by EPPENDORF
The Thermomixer R conveniently offers simultaneous mixing and temperature control. It meets even the highest demands for user-friendliness and flexibility: its counter-cooling ability provides efficient cooling, thereby greatly expanding both its temperature control functions and range of applications. Ten different thermoblocks, which can be simply and quickly exchanged to adapt to your requirements in the laboratory. Set up to two program sequences with incubating, mixing and rest phases to make everyday lab routines much easier.
[list]        [*] 10 interchangeable thermoblocks to cover tubes from 0.2 mL to 50 mL as well as plates and glass slides        [*] Wide temperature range and high temperature accuracy due to active heating and cooling capability from 13°C below RT to 99°C        [*] Adjustable mixing speed from 300 to 1,500 rpm for gentle or vigorous mixing        [*] Dry incubation technology eliminates contamination risk associated with classical waterbath incubation        [*] Insulated thermoblocks for ergonomic operation— you won’t burn your fingers        [*] Automatic thermoblock recognition properly sets speed and temperature ranges for each block        [*] 10 interchangeable thermoblocks to cover tubes from 0.2 mL to 50 mL as well as plates and glass slides        [*] Wide temperature range and high temperature accuracy due to active heating and cooling capability from 13°C below RT to 99°C        [*] Adjustable mixing speed from 300 to 1,500 rpm for gentle or vigorous mixing        [*] Dry incubation technology eliminates contamination risk associated with classical waterbath incubation        [*] Insulated thermoblocks for ergonomic operation— you won’t burn your fingers        [*] Automatic thermoblock recognition properly sets speed and temperature ranges for each block        [/list]
