AirSep - VisionAire
by AirSep
Two types of precision flowmeters
VisionAire™ 2 supports pediatric care with two types of precision flowmeters. The standard flowmeter has 1/8 LPM increments ranging from 1/8 LPM up to 2 LPM with CCM markings for easy conversion, and is suitable for adult use where lower power consumption and cooler operating temperatures are valued. The alternative flowmeter has 1/10 increments ranging from .10 LPM up to 1.0 LPM.any oxygen patients around the world rely on the everyday dependability of oxygen concentrators for all of their in-home oxygen needs. Patients and providers have long established their objectives concerning in- home oxygen. Only with the VisionAire™ series compact concentrators, including VisionAire™ 3 & 5, are all these objectives met.
FORUMSView All (4)
-MickWoods
Tue Oct 26 2021
O2 Concentrator making strange spring boing noise
Hi I am hoping someone might be able to troubleshoot my O2 concentrator. After a few minutes of use it starts to make a weird sound then eventually stops with a 4 beep warning. Here is a quick video of the sound it is making. Any help would be greatly appreciated. https://youtube.com/shorts/df6hsTEQWHI?feature=shareReply
-LD113
Fri Sep 20 2019
O2 Dropping out
Visionaire 5 O2 concentrator runs great between 1-3 lpm with an O2 output of 93%-95%. Whenever I turn the LPM up to 5, the O2 drops out to 70%... Any ideas? I was leaning towards Sieve beds or weak compressor. Reply
3
-bigel
Fri May 04 2018
four beep error code
gives four beep error. High pressure is suspected, high pressure from what?Reply
[list]  [*] Power-efficient 3 & 5 LPM unit on the market — 290 W  [*] Compact, lightweight cabinet design — 30 lb (13.6 kg)  [*] Near silent operation with a low sound level of just 40 dBA  [*] VisionAire 2 equipped with oxygen monitor. Optional for VisionAire 3 & 5  [/list]
