Cincinnati Sub-Zero - Hemotherm 400MR
The Hemotherm cooler/heater is a dual-reservoir unit that simplifies blood temperature control function during cardiovascular procedures.
The Hemotherm cooler/heater is a mobile and quiet-running system that delivers heated/cooled water to a blood heat exchanger.
FORUMSView All (3)
1Reply5 years ago | Spare part availability Hello, this model in the market more than 10 years. If anyone has information regarding its spare part availability or EOL/EOS status? Thanks!Reply |
0Replies7 years ago | Parts Where can I purchase Parts for this machine? Are there other sources besides the OEM? Will the OEM sell to an ISO?Reply |
0Replies7 years ago | Frequency of maintenance Who is doing the frequent maintenance on this unit? We are trying to figure out what level the user should be doing and what level the Biomed should be doing. Monthly: drain/refill/clean grill Quarterly: drain/refill/disinfect/alarm checks SemiAnnual: drain/refill/disinfect/alarms checks/filter clean Reply |
SERVICE COMPANIESView All Warming/Cooling Unit Companies
- Efficient Heating/Cooling
- Dual reservoirs double your efficiency
- Independent cooling and heating reservoirs permit instant changeover from one bath to the other
- Each reservoir has its own control mechanism and temperature display
- The efficient pump produces a flow rate higher than any competitor's units
- The Hemotherm lowers reservoir water temperatures at a rate that rapidly produces a significant reduction in blood temperature
- Built-in secondary Hi and Lo safety thermostats and an external circuit breaker which can be reset to enhance the safe design of Hemotherm®
- Ice is not required with this system, eliminating mess and providing simple setup
- For additional convenience an optional remote control is available to change and monitor settings of the Hemotherm® from a remote location. Microprocessor control provides easier, more accurate operation
- Large LED readout allows monitoring at a glance
- Eliminates need for calibration
- Mechanical refrigeration means easy set-up, quick response, and minimum clean up
Height | 32 in |
Length | 22 in |
Weight | 198 |
Width | 22 in |
