Analytik Jena - Specord 200, 205, 210, 250
Colorimeter
The optical components are quartz coated and equipped with high-quality encapsulation. They guarantee highest quality, maximum performance and extreme durability. The monochromator with imaging holographic grating enables stray light reduction and absolutely precise measuring results. The minimized number of movable components ensure best reliability, notably improved signal-to-noise ratio and best energy throughput. Real double-beam mode for highest precision and a better long-term stability by measuring the sample and reference signal at exact the same moment. The measurement results always show a current comparison of both beams. This way lamp fluctuation and drifts are corrected by the second beam. Furthermore is a direct compensation of the blanc solution possible.
0Replies8 years ago | Analytik jena specord 200 uv-vis spec. error issue hello i have an analytik jena specord 200 uv-vis spec. and i'm having the following error error dark measurement , value <=1ADU, use wavelenght correction. how do i solve this problem, when it come out the equipment will not work Reply |
- Intuitive software navigation
- Comprehensive method collection
- Self Check System (SCS)
- Large, easily accessible sample compartment
- Automatic accessory recognition
- Multilingual software
- No warm-up phase, plug and play
- Big, well accessible sampling area
