Varian - Cary 50
by Varian
Spectrometer
Varian Cary 50 Bio UV/ Visible Spectrophotometer has a data collection rate of an impressive 80 points per second.
-Bohong
Tue Dec 01 2015
Cary 50
Hi,
I'd like to know the following about this instrument.
1. is it brand new
2. what warranty is included
3. price.
Thanks,
Bohong
  • Software and Interconnect cable are included
  • The maximum scan rate is 24,000 nm per minute
  • Can scan the whole wavelength range of 190-1100 nm in less than 3 seconds
  • Measure samples up to 3 Abs so users won't have to dilute them as often
  • The Xenon lamp flashes only when acquiring a data point, unlike a diode array which exposes the sample to the whole wavelength range with each reading, causing degradation of photosensitive samples
  • As the Xenon lamp is very intense, the Cary 50 can use a beam splitter without the loss in energy causing excessive photometric noise
  • The beam splitter allows simultaneous reference beam correction, so peaks will not shift as the scan speed changes
  • The Cary 50's super-concentrated beam makes it ideal for fibre optic work
  • The light beam is narrow and very intense, so even if users are using microcells they will still get excellent noise performance
  • The Cary 50 is unaffected by room light
  • Users can operate with the same compartment open or closed
