Nonin - Avant 2120
by Nonin
With fast, motion-tolerant blood pressure readings and Nonin's time-tested PureSAT® pulse oximetry monitoring, the Avant 2120 gives you multi-purpose functionality while remaining lightweight and portable - a great solution for situations where mobility is key. Easy to use and compatible with a wide variety of Nonin's PureLight® sensors and blood pressure cuff sizes, the 2120 will meet almost any need in the clinic, ambulance, or even at home. The Nonin 2120 can be operated for up to 5 hours of continuous use using the included battery pack or plugged into a standard AC outlet.
-Mahran
7 years ago
How to fix error 52 in Nonin 2120?
How to fix error 52 in Nonin 2120?Reply
-darebin
9 years ago
nonin BP Oxy
the screen turns on, and then the saturation screen says OFF, and the bottom screen days USER.
How to correct?
SERVICE COMPANIESView All Pulse Oximeter Companies
[list]        [*] Monitor Blood Pressure and Pulse Oximetry in one unit        [*] Runs up to 5 hours on included rechargeable battery or AC power        [*] 33.5 hours of memory capacity for extended monitoring        [*] Easy, on-site calibration required only once per year or every 10,000 cycles        [*] Multiple mounting / transport options - rolling stands, tabletop, integrated handle        [/list]
