Philips - Respironics Esprit
Ventilator
The flexible Esprit Ventilator combines sophisticated design with easy-to-use features. This microprocessor driven unit is easily upgradeable and offers a range of modes and breath types including volume control, pressure control, and fully integrated noninvasive ventilation. Because it has no need for wall air or compressors, and can be run on either ac power, a battery pack or an external battery, the Esprit's mobility and versatility make it ideal for use in any setting, from hospital to sub-acute care facilities.
FORUMSView All (9)
2Replies3 years ago | PM Required PM Needed. This device has 147 hours. The last PM was completed in 2017. I would like to know if there is a vendor that could do the PM and send me a quote for it.Reply |
2Replies4 years ago | External Battery Where the battery is installed in esprit ventilator the external battery? From where I can purchase these rechargeable batteries? Regards - MursleenReply |
0Replies7 years ago | reg Esprit and V200 Is both Esprit and V200 same and compatible by spares and boards? Can anyone clarifyReply |
- A Range of Modes and Breath Types - Volume Control(VCV), Pressure Control(PCV), both with Pressure Support (PSV) and fully integrated Noninvasive Ventilation (NPPV)
- Multiple microprocessors for easy upgrade-ability
- Touch screen (infrared) Graphical User Interface (GUI)
- Intuitive menu structure
- Three-step setting change process
- Mode preset capability
- Pressure bargraph/breath indicator
- Prioritized alarms
- No need for wall air or compressor
- Universal power supply plus battery back-up and external battery
FDA AlertsView All
Class 1 Recall: Respironics California, Esprit V1000 and V200...
The 3rd Generation Power Supplies are installed in Esprit V1000 and V200 Ventilators and are also sold as 3rd Generation Power Supply Repair Kits.
