Vyaire - CareFusion 3100A
by Vyaire
The 3100A High-Frequency Oscillatory Ventilator (HFOV)
The 3100A High-Frequency Oscillatory Ventilator (HFOV) from CareFusion is U.S. FDA-approved for intervening in treating respiratory failure in neonates. Using lung protective tools, you can apply continuous distending pressure and superimpose minimal pressure and volume swings to inflate the lung, and avoid neonatal respiratory failure. As shown in numerous clinical and peer-reviewed studies, the 3100A helps enhance patient care for critically injured neonatal and pediatric patients.
FORUMSView All (3)
-awaldron3
4 years ago
Excessive Rain out
Has anyone dealt with rain out in the circuit of a 3100A oscillating ventilator to the point that the condensation in the circuit pooled and puddled in the circuit? I have 2 ventilators that are having this problem. The pool of water is causing the mean pressure to fluctuate greatly. After the circuit is drained and the RT adjusts the settings, the pressure will stabilize, but the pool of water eventually returns and we do it all again. I do not recall seeing this much condensation in them before or that it builds up this quickly. I have previously seen on Drager Fabius GS when the providers started to use low flow anesthesia, there was not enough fresh gas flow through the breathing system and this caused excessive rain out in the breathing system. I'm not sure if something similar may apply here? Does anyone have any insight on this? Thanks.Reply
-Jagman12
4 years ago
service manual
how to perform PMReply
-trilam9
6 years ago
Service Manual for 3100 A
could anybody please send me the SM for 3100a HFOV? ThanksReply
[list]          [*] The 3100A HFOV delivers the standard of care for more than 90% of Level III U.S. nurseries and 75% of pediatric intensive care units (PICUs).          [*] The 3100A HFOV is one of the most studied HFOV on the market today.          [*] The 3100A has been awarded the Seal of Acceptance by the alliance of Children's Hospitals, Inc.          [/list]
