DeVilbiss - 7305
by DeVilbiss
Devilbiss homecare suction unit has been designed for reliable, portable operation.
Suction unit is ideal for providing suction in the home, or on the go with the DC cord. Devilbiss suction unit has a rechargeable battery which automatically recharges when connected to the power supply. Homecare suction unit meets American Association for Respiratory Care (AARC) guidelines for neonatal, infant, child and adult homecare suctioning. Devilbiss homecare suction unit provides integrated bacterial filter.
FORUMSView All (4)
-larin
Fri Jul 31 2026
Gauge accuracy
I was just wondering if there is a way to calibrate the gauge. During a PM, I noticed that my gauge reads about 40 mmHg higher than the actual vacuum value. Is there a way to adjust or calibrate it?
-Babaw
Fri May 30 2025
Yellow flashing light
Can you tell me why Yellow flashing light will not go off after charging 24 hours?
Equipment: DeVilbiss - 7305
-Mullinsm
Mon Mar 17 2025
battery voltage
Can the older models use the 7.2V Li-Ion battery to replace the lead acid battery.
[list]    [*] 12 V DC capability for vehicle charging    [*] Uses a rechargeable battery with 60 minutes run time    [*] Automatic float shut-off to prevent overflow into the unit    [*] Switch mode power supply allows operation on any AC voltage 100 V 240 V.    [*] Vacuum adjustment allows for 80–550 mm Hg and a free flow of 27 liters/minute    [/list]
