Pocket Colorimeter
It's lightweight and battery operated, suitable for extended field work or quick, on-the-spot process monitoring. Each Hach Pocket Colorimeter II measures one to two parameters many at two concentration ranges. Each instrument comes in a ready-to-use kit that includes a manual, sample cells, and a sturdy custom carrying case.
- Lightweight and battery operated, suitable for extended field work or quick, on-the-spot process monitoring.
- The Pocket Colorimeter II is simple enough to use that anyone can obtain reliable results with accuracy comparable to that of a lab instrument.
- Each Pocket Colorimeter II Kit Instrument is pre-programmed for one of more than 35 parameters. Many are based on EPA-approved methods.
- Single Parameter go anywhere portable photometer Lightweight and battery operated, suitable for extended field work or quick, on-the-spot process monitoring.
- Fast, easy, accurate results The Pocket Colorimeter II is simple enough to use that anyone can obtain reliable results with accuracy comparable to that of a lab instrument.
- Factory-Programmed Each Pocket Colorimeter II Kit Instrument is pre-programmed for one of more than 35 parameters. Many are based on EPA-approved methods.
- No manual calibration is ever required. Simply zero the instrument with a blank, insert the reacted sample, and read the result.
- Lightweight, Rugged The IP67 rated Pocket Colorimeter II Instrument really can be carried in your pocket!
- Weighing in at only .23 kg (8.1 oz), the water-resistant and impact-resistant shell protects electronics and optics for years of trouble-free operation.
- Backlit Display, Data Logging, Recall
- Clear readings even under difficult conditions, thanks to lighting and large figures on the display.
- Record 10 most recent data points along with time of measurement. No need to carry pen and paper to manually record results.
