Fujifilm - AspireCristalle
by Fujifilm
Mammography system
The Aspire Cristalle combines innovative detector engineering with well thought out patient focused ergonomics, resulting in faster more confident diagnosis for clinicians and exceptional patient comfort.             The Aspire Cristalle brings an innovative solution to breast imaging customers around the world. New advancements include:            Patient experience enhancements, such as the patented Comfort Paddle, are designed to make the most uncomfortable part of mammograms, more comfortable. The paddle’s soft edges, flexible composition and four-way pivot contours to the individual shape of the breast to more comfortably apply compression for optimal tissue separation. The system also features new patient grip handles and padding for added stability and comfort, even soft backlighting and graphic mural decals to help ease patient anxiety and improved access for wheelchair exams, just to name a few.
FORUMSView All (3)
-Elsey220
Sat Apr 12 2025
Fuji compression
Compression stuck all the way down. Shut machine off and brought it back up. Still won’t raise. Any suggestions?
-BMcClure
Mon Feb 17 2020
Fuji Cristalle
Am looking for the technical specifications on the Fuji Cristalle. Reply
-JRJVA
Sun May 13 2018
Tomo specifications
1. Reconstruction method. ASiR or FBP? 2. Number of projections?Reply
[list]      [*] Hexagonal Close Pattern (HCP) is a detector pixel design, engineered to deliver higher acquisition efficiency, for finer detail, higher DQE, higher MTF and lower dose than conventional square pixel arrays.      [*] The system’s image quality is further enhanced with Fujifilm’s image processing, iAEC automated exposure controls and ISC precisely tuned contrast, to intelligently adapt to the specific characteristics for every breast type and to image implants with ease.      [*] Patented, flexible Comfort Paddle provides gentle, even compression of the breast and is designed to improve patient comfort      [*] Intelligent AEC (iAEC) factors in breast density to calculate optimal dose for each exam      [*] Optimized contrast and image quality — across all breast types — with ISC      50-micron pixel size output display      [*] Automatic system start-up and calibration — Aspire Cristalle is ready for work when you are      [*] Sleep mode can extend detector life as much as 300%      [*] Lower* acquisition time — only 15 seconds      [*] Adjust angle of swivel arm from +90° to -90° at a single touch      [*] Set exposure and view exposure confirmation on a single screen      [*] Easily adjust density and contrast while viewing images      [*] Aspire QC Tools allow technologists to efficiently perform accurate routine QC tests      [/list]
