ACP - Omnisound 3000 Pro
by ACP
ACPs Omnisound 3000 line is the most extensively researched ultrasound device available and is supported by numerous research articles.
The 3000 Pro offers evidence-based operational protocols and can be used in "Pulsed" or "Continuous Modes" for both thermal and sub-thermal applications. Importantly, it offers an advanced uniform beam with the lowest Beam Non-uniformity Ratio (BNR) and Peak Area of Maximum Beam Non-uniformity Ratio (PAMBNR) in the industry for consistent heating effects and patient comfort.
This exceptional beam uniformity supports safer treatment for geriatric patients with reduced muscle mass and sensitive joints. In addition, the system’s patented Delta T Temperature Dose Control Technology insures reproducible dosage for treatment consistency and clinician efficiency. The system includes two different sized transducer heads (2 & 5 cm) that rotate 360 degrees for more effective and efficient treatment. Each of these transducer heads is designed to be used on targeted surface areas and deep tissue with the flexibility of 1 or 3 MHz power options. The Omnisound 3000 Pro also offers a protocol-use recording function to monitor utilization.
FORUMSView All (3)
-DRLMES
Thu Dec 05 2024
ops manual
looking for the operators manual
Equipment: omnisound 3000
-LD113
Tue Apr 26 2016
Omni Sound 3000
Does anyone have any insight on the RF Failure for the Omni Sound 3000?
-Sports Rehab
Thu Jun 04 2015
3000C
Can I order a new cover for my large sound head controller? How?
Thanks,
Steve
ShockwaveYES
Ultrasound therapyYES
