Lumenis - VersaPulse PowerSuite 20w
PowerSuite 20w LASERThe VersaPulse® PowerSuite™ 20 Watt holmium laser is the low-powered member of the VersaPulse PowerSuite family. This makes it an economical choice if lithotripsy is the primary procedure performed in your hospital.
FORUMSView All (5)
0Repliesa year ago | Fault 104- Data/ program flow incorrect Getting this error. Any idea as to what causes this? Reply |
1Reply2 years ago | Erreur F452 Ma machine signale l'erreur F 452. Pouvez vous m'aider Reply |
1Reply5 years ago | Procedure of Servicing machine How to service that machine Can you provide Videos OF troubleshottingReply |
[list] [*] Compatibility with a wide variety of reusable and disposable delivery devices, allowing surgeons to select the exact tool needed for every procedure [*] Maximum flexibility for rapidly completing a full spectrum of procedures and reducing anesthesia time [*] Compact design for easy transport from one room to another [*] For the dual-wavelength model, effortless switching between holmium and Nd:YAG wavelengths with the touch of a pedal for quick changes in tissue effect [/list]
Laser Type | Holmium |
Height | 45 in |
Length | 24 in |
Weight | 185 lbs |
Wavelength | 2100 nm |
Width | 19 in |
