GE HealthCare - Brivo OEC 850
by GE HealthCare
Mobile C-Arm
The high-quality, versatile OEC mobile C-arm makes surgeries more accessible than ever to facilities and their patients. The surgical staff needs a mobile C-arm that helps them produce clear crisp images quickly. Made simple to operate, easy to maneuver, comfortable to use, the Brivo OEC 850 is focused on productivity.
FORUMSView All (13)
-VanndaMedical
2 years ago
troubleshooting
First the fuse was damaged and after we changed the fuse it cause the power board burn when we started the machine. Thank you.
Equipment: GE Healthcare - Brivo OEC 850
-niekhuh
2 years ago
TECNICAL MANUAL
Good day ! Does anyone here has a TECHNICAL MANUAL of OEC 850 C arm , im having a hard time in fixing the problem . There were no errors indicated , when I test it with my hand there will be an image but when abdominal test the result were GREY is it under exposure ?
-jualro17_8372
2 years ago
Brivo OEC 850 service manual
Hello dear: I would need the technical service manual for the Brivo OEC 850 equipment. I get some online but some manual pages are blurry. Thanks a lot. Reply
SERVICE COMPANIESView All Mobile C-Arm Companies
  • Superb image quality
  • Simple operation
  • Maneuverability in tight spaces
  • Robust image management
