ZEISS - OPMI VISU 160
by ZEISS
OPMI VISU 160 was designed specifically for hospitals that perform a broad spectrum of procedures in ophthalmic surgery.
FORUMSView All (3)
-PaulLUK
Sun Jan 14 2024
Removing Illumination Module from Microscope head
Please can anyone tell me how to remove the illumination module from the microscope head. I believe that someone has jammed an undersized fibrelight cable in the module and damaged the filter wheel. I have a manual and page 49 shows it separated but not how it is removed. Any help would be much appreciated.
Equipment: Zeiss Visu 160 OPMI Ophthalmic Microscope
-gwm365
Wed Jun 03 2020
oculus focus
Hi Guys, i wonder if any of you with experience with this unit can help. a surgeon in a clinic has got in contact with the following complaints abut this unit 1. "the focus of the oculus between right and left is not in sync" 2. "the focus is two diopters out" is there an internal adjustment that can be made to adjust the focus? best regards, GWM365Reply
-KBujang
Tue May 31 2016
cannot focus down
no movement when press focus down
  • With a push of a button, surgeons can choose the type of microscope image they want to see through the OPMI VISU 160
  • When DeepView is activated, OPMI VISU 160 is able to deliver razor-sharp depth perception with every magnification
  • Deactivate DeepView to provide optimum light transmission for a bright image with high resolution - even with low illumination
