Hitachi Medical Systems - ECLOS
ECLOS is a very reliable and patient friendly 16 slice CT system using advanced filter technology to produce low-dose imaging.ECLOS delivers excellent image quality results, cost effective operating economics and excellent uptime. This cross-sectional imaging device is easy to operate, and the automatic positioning system guarantees a smooth workflow.
FORUMSView All (4)
1Reply2 years ago | Hitachi ECLOS 8 Maintenance Password Hi , i have Hitachi ECLOS 8 i have problem with hard drives and file missing from system and it request Chkdsk and i need the maintenance password to do it so if someone can help ! .Reply |
1Reply3 years ago | Problem of Hitachi Eclos 8 Filming Tool - When i print the film results just images are in each others no layouts !! - I have hitachi eclos 8 2008 with Agfa Drystar 5302 dicom printer My Problem is when i do filming i chose all my images my layout and my film size every thing is alright but the printed film result is that images are not organized are in each others and croped randomly i can't find the solution if anyone can help !Reply |
0Replies8 years ago | Have just purchased a used Eclos 4 slides I have just purchased a used Hitachi Eclos 4 CT scanner and I cannot find the electrical design plan to give my electrical contractor. Reply |
SERVICE COMPANIESView All CT Scanner Companies
[list] [*] Sub-second, real-time image reconstruction [*] Straight forward patient registration and easy system handling [*] Preventive examination supported by fatPointer or riskPointer [*] Integrated image viewing station [*] Automatic patient positioning (head/body mode) [*] Breath demo light for patient preparation [*] Maximum care for patient and clinician! [/list]
Slices | 16 |
Maximum Scan Range | 500 mm |
Gantry (Max. Clearance) | 70 cm |
Patient Weight Capacity | 495 lbs |
[list] [*] X-ray tube: 3.5 to 5.0 MHU [*] Generator: 48kW [*] Other rotation speed options: 1.0, 1.5, 2.0, 3.0 seconds [*] Minimum rotation speed: 0.8 seconds [*] Gantry diameter: 70 cm [*] Maximum beam width (cm) 2 cm [*] Minimum room size (length x width x height): 240 sq ft, l x w [*] Table weight limit: 495 lbs [*] Table movement range vertically/longitudinally: 42 to 100 cm vertical, 186 cm horizontal [*] X-ray generator kV range: 100, 120, 130 kVp [*] Maximum scan range: 175 cm [*] X-ray tube heat capacity: 5.0 MHU [*] Power requirements: 208 VAC, 3-phase, 200 Amp max. [/list]
