Philips - ClearVue 350
by Philips
Ultrasound System
A Philips quality imaging system through and through, the ClearVue 350 with Active Array technology offers image quality designed to enhance diagnostic confidence, features that are sophisticated enough to be simple, and advances in ease of use and reliability. The elegant design and graceful lines of the Philips ClearVue 350 ultrasound system only hint at the power within.
1ReplyFri Jan 24 2025 | How to go about it Diagnostic code 0001.97ECPW46.0 On pressing ‘service’ it asks for the login password Equipment: Philips - ClearVue 350 Reply |
0RepliesTue Aug 27 2024 | Philips clearvue 350 Au démarrage l'appareil prend plus 1h30 ou 2h du temps avant de s'allumer. Quelqu'un a déjà rencontré ce genre de problème. Peut-être que vous m'aiderez à résoudre ce problème? merci Equipment: Philip clearvue 350 When starting up, the device takes more than 1h30 or 2h before turning on. Has anyone encountered this kind of problem before? Maybe you will help me solve this problem? thank you Equipment: Philip clearvue 350 Reply |
5RepliesThu Mar 23 2023 | BootUp I have an issue with my system. After I power up the ultrasound machine, a blue screen with error information appears on the screen as problem detected and windows has been shut down to prevent damage to your computer and also disable or uninstall any anti-virus, disk defragmentation, or backup utilities. Can you please assist me in troubleshooting this particular error? Equipment: Philips - ClearVue 350 Reply |
