Stryker - Trio Mobile
by Stryker
The Stryker Trio Mobile Surgery Platform will virtually eliminate patient transfers! Think of this as a stretcher, surgical table and post-op recovery bed all in one. The Trio mobile surgery platform helps eliminate transfers in the OR by allowing patients to remain on the same surface for pre-op, procedure and post-op. This unique specialty platform accommodates all commonly used surgical positions, which make it ideal for the ASC environment.
2RepliesTue Nov 18 2025 | Stryker 1033 Trio Pedestal lift jack I'm looking for Stryker Part 1033-001-050 the pedestal lift jack assembly for the Stryker 1033 Trio Stretcher Equipment: Stryker Trio 1033 Reply |
0RepliesSun Oct 05 2014 | TRIO WONT JACK UP I have a Stryker Trio that has stopped raising when any of the foot pumps are used. there are no oil leaks, I can see the rod and spring moving when pumped but no lift. Any help is appreciated. Randall Norris Bayside Biomedical 813-677-8696 Reply |
[list] [*] Quadra Channel™ stabilizing lift system [*] Siderails enable fluoro clearance [*] Four IV receptacles [*] Four-wheel, steel-ring brakes with dual side [*] activator [*] Backrest raises to 80° [*] Removable foot section (0° - 50) [*] 20° Trend./15° reverse Trend [*] Left and right lateral tilt ±15° [*] Ultraview litter top for unobstructed [*] fluoroscopic access [*] Three-sided foot controls for lift/lower [*] Retractable fifth-wheel steering [*] Low profile base with thermoformed hood [*] Full-length surgery accessory rail [/list]
