Fujifilm - FCR PRIMA
by Fujifilm
The FCR PRIMA is one of the most compact and lightweight reader units on the market. The required space is comparatively smaller than other similar table-top systems and can be installed in any open space. The FCR PRIMA Console is a complete image management workstation that is designed for simple and fast patient identification, image acquiring and processing, as well as image viewing, reprocessing, optimizing, and archiving.
1ReplyTue Jul 07 2026 | ERROR 222 Buenas noches, para ver si me pueden ayudar con este error 222 en una digitalizadora. Equipment: FUJIFILM FCR PRIMA T Reply |
5RepliesThu Jun 25 2026 | Service and Operator Manual FujiFilm Prima Tm Do you have a soft copy of FujiFilm Prima Tm? If you have, please send me a copy. Thank you. Equipment: FujiFilm Prima TM Reply |
2RepliesSat Jun 20 2026 | Manual service and manual operator FUJIFILM FCR T2 Hello, I need the Service Manual and Operator's Manual for the FUJIFILM FCR T2 system, if anyone has them available, in order to perform preventive maintenance. I am specifically looking for the complete step-by-step procedure, from equipment disassembly through final startup and commissioning after maintenance. Any assistance or documentation would be greatly appreciated. Thank you. Equipment: Fujifilm - FCR PRIMA Reply |
[list] [*] Compact footprint, only 0.24m2 [*]Stable and optimized images [*]Flexible reading in various sizes [*]Throughput of up to 29 images an hour [*]Repeated use of IP [/list]
| Height | 31 in |
| Weight | 70 kg |
| Width | 24 in |
