Siemens - Acuson SC2000 Prime
by Siemens
With innovations such as simultaneous anatomy and blood flow visualization with real-time volume color Doppler and aortic and mitral valve 3D modeling, this premier volume ultrasound system delivers all the information users need in the moments it matters most.
The ACUSON SC2000 ultrasound system is a pioneering cardiac ultrasound platform that combines ultra-high data rate echo engine with a suite of advanced applications to simplify echo for users. Defining tomorrow’s standards in 2D and full-volume echo.
0Replies3 years ago | Need sc2000 prime tech manual Ekg flatline not fixed by new cable. Need to check EKG box. How do i remove the front of the machineReply |
0Replies6 years ago | M-Mode operation. In order to rotate M-mode knob for gain do you have to tap the selection knob once or twice. It appears that if you only tap the M-mode once it will not increase gain when you rotate. I do not have access to a Operators manual so any help would be appreciated. Reply |
1Reply6 years ago | Change facility name Can someone assist with changing the facility name? If it is done through the local service portal, do you have the log in info?Reply |
