3M Health Care - Steri-vac 8XL
Sterilizer
3M's largest capacity EO sterilizer. A single unit-dose EO cartridge is punctured inside the negative pressure chamber only when proper chamber conditions are achieved. The extra-large chamber with a full-sized lower basket and two half-size upper baskets provides economical processing of large loads or larger surgical instruments. The model 8XL features a sensing system that continuously monitors and controls relative humidity during the pre-conditioning phase to optimize moisture required for the exposure cycle (two temperature cycles: 55°C and 37°C). Dependable computer controlled electronic design provides accuracy, and automatically stops the cycle and displays codes if an error is detected. Digital display continuously shows cycle status.
FORUMSView All (8)
2Replies3 months ago | Error 22 When I run the sterilizer, the display temperature is out of range (37 °C) and the pressure stops at 260mBar. Consequently, I get the error message E22. The compressor air pressure is fine, the vacuum pump is good, and there is no leak. Any idea of what I can do to fix it. Thanks, Equipment: Sterilizer 3m Steri Vac 8XL Reply |
2Repliesa year ago | Service manual Hi. I need sterivac 8xl service manual Reply |
1Replya year ago | Replacement parts request Hi, I am in Panama and require urgently the following replacement parts for 3M Sterivac - 8XL: QTY Part No. Description 2 78-8078-6778-9 Solenid, valve , 3-way 1 12-2376-3912-0 Valve. Check 1 78-8078-0332-1 Assembly, Puncture Cylinder/ switch 1 12-2376-3296-8 Transducer, vacuum venturi 1 12-2376-9138-6 Solenoid, valve 1 78-8078-5708-7 Temperature sensor assembly I will be attentive to receiving any part supplier contact info so we can get in touch with them.Reply |
- Digital display continuously shows cycle status
- Single unit-dose EO cartridge is punctured inside the locked, negative pressure chamber only when proper chamber conditions are achieved
- Continuous temperature monitoring automatically maintains the selected cycle temperature
- Ethylene oxide is a proven, efficacious sterilant offering maximum assurance that instruments are sterilized
- Large chamber nearly doubles sterilizing capacity compared to other models
- Built-in aeration begins automatically after sterilization and reduces potential for EO exposure
- The only hospital EO sterilizer with a direct RH sensor to document, control and provide optimal humidity to each load
- No CFCs or HCFCs mean a low temperature sterilization system that's compatible with the environment
- Low cost per cycle offers cost-effective means of low temperature sterilization
Chamber Volume | 7.9 cu. ft. |
Chamber Width | 20 in |
Height | 70.5 cm |
Chamber Height | 18 in |
Chamber Depth | 38 |
Width | 37 in |
