GE HealthCare - iVent 201
by GE HealthCare
The iVent201 is a compact, portable, fully-featured, microprocessor-controlled ventilator
With its comprehensive list of standard features, including the latest modes of ventilation, the iVent201 is appropriate for all levels of patient acuity, from pediatric through adult, and in all care settings, from the patient’s bedside to transport to another point of care.    With its highly featured transport capability and rugged construction, the iVent201 takes ICU ventilation outside of the confines of the hospital. Optimized NIV and the Adaptive Bipap help caregivers maximize patient comfort and synchrony.
FORUMSView All (7)
-Mr Asgarli
Tue Jun 24 2025
Calibration Oxygen sensor M-16 but 100% failed. Why?
Hello everyone ,
Can someone support me how to calibrate the oxygen sensor Ivent201 versamed?
-Skip
Sat Feb 20 2021
Error 387
Hello Group, i need help identifying error 387 on a i vent 201 ventilator. This error shows on the error log screen. Thanks in advance.Reply
-Precise Medical Engineers
Sun Jun 07 2020
I vent 201 is not working either than bipap
I vent201 is only showing bipap ventilation can someone help thanksReply
[list]    [*] Assist/Control    [*] Volume Controlled A/C    [*] Pressure Controlled A/C    [*] Volume Controlled SIMV    [*] Pressure Controlled SIMV    [*] Continuous Positive Airway Pressure (CPAP)    [*] Pressure Support Ven    [*] Adaptive Bi-Level* (NIV)    [*]Preset parameters by patient weight    [*]Apnea backup ventilation    [*]Adjustable rise time    [*]Easy Exhale    [*]Sigh breath    [*]100% O2 suction    [/list]
Height13 in
Length 10.3 in
Weight10.3 lbs
Width9.5 in
Ventilator Respiratory Rate: –1 to 50BPM    Tidal Volume: 100 to 2000ml    Inspiratory Pressure Limit: 5 to 80 cmH20    Inspiratory Time: 0.3 to 3 or Adaptive I-time    Peak Flow: 120 L/min or Adaptive Flow    Peak Flow: up to 180 L/min    PEEP: 0 to 20 cmH20    Trigger Sensitivity: 1 to 20 l/min(flow trigger)or off, -0.5 to -20cmH20 or off    Psup: 0 to 60cmH20    Postive Pressure Relief Valve: 80cmH20    Pressure Control: 5 to 80cmH20
