CareFusion - Alaris EtCO2 Module 8300
by CareFusion
Infusion Pump
The Alaris™ EtCO2 module brings continuous respiratory monitoring to all patient care areas with an easy-to-use technology that is effective with both intubated and non-intubated mobility. This essential respiratory technology adds an additional layer of protection at the point-of-care that pauses a PCA infusion if a patient falls below your hospital-defined respiratory limits when used with the Alaris™ PCA module. Its features include customizable profiles that add flexibility across all patient care areas.
The Alaris EtCO2 module utilizes sampling lines that eliminate the need for moving parts, external sensors or routine calibration. The Oridion FilterLine™ family of EtCO2 breath sampling lines provide highly effective oral and nasal sampling, even from patients with low tidal volumes. Oridion provides patient EtCO2 sampling products to meet a broad spectrum of sampling needs available with or without oxygen delivery.
FORUMSView All (4)
-anniepowers19
Mon May 02 2022
Error Codes
I got an error code 571.6241 It is not listed directly in the manual. Has anyone seen this before? Do you know how to fix this issue?Reply
2
Thu Jan 13 2022
calibration gas range
alaris etco2 module. can 2.5% co2 in air be used for calibration? Reply
6
-BMETStu
Thu May 28 2020
Connection Hose for Gas line
Hello I am looking for the part number for an EtCo2 hose that goes between the pump and the test Gas Cylinder. Does anyone know where I could purchase these?
https://drive.google.com/file/d/1beiLf6lnzUhXIdKXzjp76TGGRDPKV7O4/view?usp=sharing
  • Supports current ASA and Joint Commission standards mandating CO2 monitoring for all anesthetized patients (intubated and non-intubated
  • Provides an additional safety net at the bedside to continuously monitor patient respiratory response to infusion therapy
  • Provides a unique function for the clinician to automatically pause a PCA infusion if a patient falls below your hospital-defined low respiratory limits when used with the Alaris™ PCA module
  • Dose error reduction (DERs) system
  • Customizable alarm limits by care area
  • Trending data alongside PCA dosing data
Height8.9 in
Weight2.5 lbs
Width3.3 in
