Datascope - Accutorr 4
by Datascope
Datascope ACCUTORR 4
[list] [*]Uses oscillometric technique to rapidly and accurately measure non-invasive blood pressure (NIBP), heart rate and monitor oxygen saturation (SaO2) [*]Monitor provides large front panel digital readouts [*]Manually initiated or automatic sequential measurement cycles [*]Integral LCD display for reading trended data, advisor messages, alarm conditions, elapsed time, a 24 hour clock and SaO2 waveform [*] Automatic NIBP measurement cycle uses a continuous timer which allows for sequential measurements of NIBP [*]SpO2 [*]NIBP [*]Automatic blood pressure with adjustable time intervals and adjustable alarms. [*]Mean and Pulse Rate [*]Optional recorder [/list]
Height | 9 in |
SpO2 Range | 0-100% |
Width | 6 in |
Dimensions: 9 ¾” H x 6 ¼” W x 13 ¾” D Weight: 12 lbs 4 ozs without battery; battery: 1 lb 14 ozs Battery Type: sealed, lead-acid, 12 V, 1.9Ah; Operating time: 2 hrs. with timer interval set to 5 minutes and without SaO2; 1 hr with timer interval set to 5 minutes with SaO2; Recharge time: 16 hours SaO2 range: Adult and Neonate: 0 to 100% SaO2 accuracy: 3 digits; 70 to 100% < +/- 2% 60 to 70% < +/- 4% <60%, unspecified. Initial Cuff Inflation: Adult/pediatric: 180 +/- 15 mmHg; Neonate: 120 +/- 15 mmHg Cuff Pressure Range: Adult/pediatric: 0 to 270 mmHg; Neonate: 0 to 230 mmHg Power requirements Voltage input: Models: -10, -11, -12, -13; 108 to 132 VAC; 57-63 Hz 30 W typical Models: -20, -21, -22, -23; 198 to 264 VAC; 47-57 Hz 30 W typical, 0.2 A max.
