Zoll - IVTM
Temperature Monitoring System
ZOLLs Intravascular Temperature Management (IVTM™) system provides cooling and warming from a catheter inserted into a patients vein. This provides rapid and precise control of the core body temperature by directly cooling or warming the patients blood as it flows through the body. This catheter is connected to the Thermogard XP® console, which circulates ice-cold saline solution inside a multi-balloon catheter. The Thermogard XP precisely maintains target temperature within 0.2C and can slowly rewarm the patient to normal body temperature. Since the saline flows only within the catheter, no fluid is infused into the patient. The ZOLL IVTM system is efficient, precise and easy to use, and enables unhindered access to the patient.
- Rapid and precise core body temperature management
- System automatically maintains target temperature
- Software enables real-time temperature display, storage and download
- Easy-to-use, multifunction catheters
- “Hands-free” operation reduces nursing time
- Improved access to patient
Height | 45 in |
Length | 30 in |
Weight | 115 lbs |
Width | 17 in |
- Operating Temperatures: 10°C – 27°C (50°F – 81°F)
- Configuration: 100-120 VAC, 50/60 Hz, 5A 220-240 VAC, 50/60 Hz, 2.25A
- Voltage: 115 V, 230 V
- Fuse Protection:T6.3A (slow blow) 5 x 20 mm
- Operating Humidity: 30 to 75% noncondensing
- Atmospheric Pressure: 70 kPa to 106 kPa
- Reservoir Volume:2.0 liters (0.5 gal)
- Pump Capacity:7 lpm at 0 m head (0 ft)
- Temperature Range:0°C – 42°C
- Refrigerant: HFC 134a
- Screen Display:6.4 in. (16.25 cm) LCD color VGA
- Controls:Push buttons and knob
- Temperature Input:Thermistor, YSI-400 series
- Articulation:180° swivel, 45° tilt
- Data Interface:Serial RS-232C, 9-pin sub-D connector
- Alarms: Audible tones and displayed text messages
- Displayed Temperature Range: 26°C – 42°C
- Displayed Temperature Accuracy: ± 0.2°C
