TBS Triangle Biomedical - SHUR Stain 3030
by TBS Triangle Biomedical
Slide Stainer
The SS-3030 SHUR/Stain Slide Stainer offers continuous loading with multi-protocol management.
-Data Entry Coordinator
Tue Jan 13 2015
SHUR/Stain™ 3030 H&E Slide Stainer
-justeng
Sat Jan 10 2015
Service Manual: SHURStain 3030
Does anybody have a Service Manual for a TBS SHURStain 3030 stainer?
Thank you!
VIDEOS
  • State-of-the-art, user-friendly operator interface with color touch screen
  • Built-in fume extraction or can be connected to lab fume exhaust system
  • 30 stations, five rinse stations, two water inlets
  • Continuous Loading
  • Multi-protocol Management
Height26 in
Length 30 in
Weight125 lbs
Width39 in
  • Compact footprint: 34 in. (86cm) wide
  • Number of programs: 50
  • Display: Active matrix TFT 6.5 in. display
  • Voltage: AC Factory set for either 100-120 volts or 230 volts operation, 50 or 60 Hz
  • Fuse rating: 10 Amp x 250 volts Time Delay (Slo-Blo) fuse for 100-120 volts units
  • Number of Stations: 30
  • Number of Rinse Stations: 5 (user selectable)
  • Rinse Water Flow Control: Software programmable for 1 station individually adjustable for 5 stations
  • Number of Load Station: 1
  • Number of Unload Station: 2
  • Reagent Container Volume: 350 ml
  • Slide Carrier Capacity: 30 slides
  • Drying Station Temp. Range: 40° C – 70° C
  • Display: Active matrix TFT 6.5” display
  • Touch Screen: Resistive touch pad
  • Programmable Flow Rates: 500, 1000, 1500, and 2000 ml/min, programmable for individual step.
