TRUMPF - Tisch Mars
by TRUMPF
Trumpf Tisch Mars
The versatility of the mobile OR table MARS is impressive: five base versions that can be individually configured, facilitate adaptation to almost any work environment. At the same time, MARS offers maximum functionality – in every discipline. An ideal framework to meet the increased demands of daily clinical practice, and to design procedures more efficiently. Which represents a worthwhile investment in the future of any clinic            The mobile OR table family MARS offers a large selection of models, covering a broad application spectrum. The base models with standard height and as a low version are designed for multi-functional use and meet specific requirements for every surgical discipline.
-alexbenjamin
Tue Jan 06 2015
TRUMPF Tisch Mars Operating Table - Sensor Callibration?
Hello All,
We've a Trumpf Tisch Mars operating table whose leg section we cannot get to descend fully.
We can drop the legs to around the horizontal position but no further. Rather frustrating!
Any able to advise on what's next? Trying to avoid the obvious telephone call to the manufacture as call out charges are horrendous.
Many thanks in advance!
Alex
[list]      Free choice of table top combinations      [*] A permanent component of the base version is a tabletop that can be adjusted in the longitudinal direction. The tabletop of the base models consists of a seat base and a lower back section. All supplementary modules have almost unlimited combination options. This saves on unnecessary additional expenditures, and you always obtain exactly the mobile OR table that you really need.            Functionality for any discipline      [*]Owing to its diverse functionality and almost unlimited configuration options, the MARS table easily changes from an all-round performer into a specialist. The motorized longitudinal adjustment permits precise positioning under the C-arm for intra-operative imaging. For 360° radiolucency, use our full line of carbon fiber components and accessories.            [*]Intelligent solutions for improved ergonomics      The motor-driven carriage simplifies patient transport and can be readily controlled via the operator console QuickMove. Large wheels ensure secure steering, even on uneven floors. In the OR, four electric motor-driven extendable feet guarantee a secure stance (MARS 2.03, 2.04, 2.05). In this position, the wheels rotate freely and can therefore be easily cleaned. The Y-shape of the chassis assures optimal foot and leg room.            [*] Low versions for light work while seated      [*]Well-thought-out solutions for more ergonomics      [*]Comfortable linkage with most modern OR management      [*]Highest reliability and cost-effectiveness      [/list]
Patient Weight Capacity1000 lbs
Max. patient weight: up to 1,000 lbs / 450 kg        Height adjustment: 700 mm - 1120 mm        Height adjustment (low version): 600 mm - 950 mm        Longitudinal shift of the table top: 10.5 inch / 270 mm        Trendelenburg: / Reverse Trendelenburg - Trendelenburg: 30 ° | Reverse Trendelenburg: 35 ° | Trendelenburg (low version): 25 ° |Reverse Trendelenburg (low version): 35 °        Tilt: ± 25 °        Leg rest adjustment: up + 90 ° | down - 90 °        Pelvis extensions: adjustment + 90 ° / - 100 °        Upper back section: adjustment + 90 ° / - 55 °        Lower back section: adjustment + 80 ° / - 40 °
