Motomed - Viva 1
Bicycle
The most sold motor driven, software-controlled movement therapy machine for people with paralysis, spasticity and physical weakness. Ideal for daily passive, assistive and active movement training in the rehabilitation center, skilled nursing facility, or at home. Movement trainer MOTOmed viva 1 arm trainer Incl. Arm trainer, foot rests, leg support (with calf shells) and a grip. For patients with limitations in the hand, arm and shoulder movement therapy can be expanded with the Motomed upper body workout. The MOTOmed viva supported and enabled with the RMV-pedal assistance even the slightest own forces. This can be built up strength and motor skills. Other features: Anti-Spasmensteuerung with automatic adjustment easy entry with safety stop flexible training starts soft acceleration and deceleration speed control from 0 to 60 U / min automatic motor power adjustment (from 2 to 17 N / m be limited) multiple program settings high quality and safe . all-metal construction , the footrests (pair) are comfortable and non-slip. The leg guides give the leg rests. The feet and legs are fixed by pleasant loop tapes. The leg guides are hinged and adjustable without tools in height
FORUMSView All (5)
1Reply3 years ago | Fallo motor Al encender ininia de forma muy rapida y violenta el pedaleador y de repente se para. Aparece el texto" sin motor" Por otro lado, en la parte para entrenar brazos no hay incidencias Gracias Reply |
3Replies3 years ago | Uk instruction manual Just purchased one of these 2nd hand and I would like to know where to get a uk manual from pleaseReply |
1Reply5 years ago | How to get to the motor Hello, The motor of a Motomed Viva 1 is broken. I do not have the servicemanual and have no idea how to get to the motor. Have deassembled everything. Please can anyone help out?! Much appreciated, OscarReply |
- Moving gently legs or arms (arm/upper body trainer as accessory available): passively, assitively or actively
- Integrated therapy support with ServoCycling, SmoothDriveSystem, SymmetryTraining.
- For your safety: SpasmControl with automatic direction change, MovementProtector, safety foot shells
- Moveable and slip-proof (all metal construction)
- Gently moves legs or arms (arm/upper body trainer accessory is available): passively, assitively or actively
