Konica Minolta - Regius 190
by Konica Minolta
REGIUS MODEL 190
Succeeding the "Ultimate Resource Sharing System" concept introduced in REGIUS MODEL 170, the new REGIUS MODEL 190 features a new 43.75Μm read function for mammography, the finest in the world.             The REGIUS Console has also been enhanced with new functions to provide more powerful tools.
FORUMSView All (28)
-Kim Sr
Sun Apr 21 2024
PC Upgrade
We upgraded our PC's operating system from WinXP to Windows 7.  Need available CS2 Software for our Regius 190.  Or do you recommend upgrading to CS7 as well?  Need Software.  Thank You
-Kim Sr
Sun Jan 14 2024
REGIUS Console-CS2 Login name & Password
Please help.  I need Login name & password for REGIUS Console-CS2.
my email: linksys014@gmail.com
-slimreaper53
Sun Jul 30 2023
service key
service key needed to install printer. Any help?
Equipment: Konica Minolta - Regius 190
A new Compact, high-performance design.          Utilizing a unique dual bay design?the high speed reader of REGIUS Model 190 processes up to 90 plates per hour for maximum performance. This next generation reader radically improves workflow all within a mere 58×58 cm footprint.                    Centralized image checking for flexible layout          The "Ultimate Resource Sharing" concept provides the flexibility to separate the location of the consoles and the readers. This allows for the same fast and through image checking as with conventional systems. The result:system layout and productivity are optimized according to the number of examinations conduded, the work line and floor space.                    2ch slot with independent insert / eject simplifies operation.          ln this uniquely innovative design, the entire cassette is loaded into the front slot and ejected out of the rear slot. This helps make the examination handling process exceptionally smooth and efficient.                    43.75Μm Read Function (option)          ln addition to the 175 and 87.5Μm read capability, REGIUS MODEL 190 is capable of supporting a new 43.75Μm read function for mammography ?outside US?. This function is invaluable for producing diagnostic quality for mammography images, where recognition of subtle pathological changes is essential.                    Featuring a new cassette size to provide the ideal examination environment.          ln addition to the world's first 11"×14" size featured in REGIUS MODEL170, the new line-up available on REGIUS MODEL 190 includes the 15×30cm size to provide even greater examination efficiency.
Exposure size: 14”×17”/14”×14”/11”×14”/10”×12”/8”×10”/           18×24cm/24×30cm/15×30cm and others          Sampling Pitch: 3Types:87.5/175 and 43.75Μm for Mammography             Digital Gradation Level: 4096 levels (12bit)          Processing Capability: approx. 90plates/hour (14”×14”/175Μm)          Cassette Feed/Load Time or Cassette Cycle Time: approx. 40 seconds (14”×14”/175Μm)          Slots:           [*] Insert×1 (plus 1 stack)           [*] Eject×1 (4-stack)          Outer Dimensions/Weight: W580×D580×H1230mm/approx. 170kg          Power Consumption: AC100/115/120/200/220/230/240V ±10%           50/60Hz approx. 1.1kW
