STERIS - AMSCO Century V120
by STERIS
The Amsco Century Small Sterilizers are designed for sterilization of materials used in healthcare facilities. They are available in two configurations:
Gravity: designed for sterilization of heat and moisture-stable materials and sterilization of items intended for immediate use. Gravity sterilizers are equipped with gravity and flash cycles.
Prevacuum: designed for fast, efficient sterilization of heat and moisture-stable materials in addition to the same sterilization capabilities as a gravity sterilizer. Prevacuum sterilizers are equipped with prevacuum, gravity, flash, express, leak test and daily air removal test cycles
5RepliesSat Oct 19 2024 | Humidity Need Humidity Limites for the Century V-120, JACHO says we must know this so we don't oper: said same in the wrong inverioment,,,,,,,,???? should be somewhere in the enviromental operational peramitures... Reply |
0RepliesMon Oct 02 2023 | error 259 mil equipo da error 259 falla de comunicacion con entradas y salidas Reply |
2RepliesThu May 26 2022 | Steris V120 service manual I am looking for a Steris V-120 service manual. If anyone could help me out it would be greatly appreciated. My email address is ercast50l@gmail.com. Thanks in advanceReply |
Control System
Vertical Sliding Door
Modular Vessel and Piping
| Orientation | Floor Standing |
