Covidien - Capnostream 20P
by Covidien
The Capnostream® 20 Capnography Monitor is a bedside patient monitoring system designed for use across all hospital environments and patient populations, including adult, pediatric, and neonatal care. Engineered with Microstream® Smart Capnography™ technology, the Capnostream® 20 uses advanced Oridion algorithms to deliver accurate end-tidal CO‚ (EtCO‚) and respiratory rate monitoring while reducing clinically insignificant alarms*. This intelligent alarm management supports improved patient safety, workflow efficiency, and clinical decision-making. Ideal for biomedical engineers, the Capnostream® 20 integrates reliable capnography performance with scalable hospital deployment, making it a trusted solution for respiratory monitoring in critical care, procedural, and general care settings. (Generated by AI)
5RepliesSat Feb 01 2025 | trouble shoot The time on the unit always shows the time is it was last turned off. Any help here. Equipment: Covidien - Capnostream 20P Reply |
3RepliesFri Apr 21 2023 | Service manual Does anyone have Service manual for it or service data password? I got bunch of monitors with "SpO2 Error" after RTC battery died. Reply |
2RepliesThu Mar 18 2021 | SpO2 Error The saturation prob is not showing the reading but prob detection light is on.. i have changed many probsReply |
[list] [*] CO2 -specific emission source eliminates need to calibrate for presence of other gases [*] Accurate and reliable in the presence of various gases and for a wide range of temperature environments [*] No need for manual calibration and zeroing, water traps, or flushing monitor between patients [*] Flow rate of only 50 ml/min, especially suitable for neonatal sampling [*] Utilizes small sample cell (15 µl) for quick responsiveness and accurate monitoring, even with high respiratory rates [*] Shown in a clinical study to reduce clinically insignificant alarms* by 53% with the Oridion Smart Capnography SARA™ algorithm [*] Recognizes changes in ventilatory and oxygenation status with the Integrated Pulmonary Index™ (IPI), which combines etCO2, respiratory rate, SpO2, and pulse rate into a single, 1 to 10 index [*] Connectivity to nurse call, paging, and central monitoring systems including Bernoulli from Cardiopulmonary Corporation, Masimo Patient SafetyNet, and Philips systems using VueLink modules [*] Battery with two hours of power for patient transport [*] Choice of Masimo or Nellcor pulse oximetry technologies [*] Large, bright color display with an easy-to-use, knob-navigated, flat-menu structure [*]Data export capabilities through standard USB output [/list]
| Height | 6.6 in |
| Length | 7.6 in |
| Power Requirements | 100-240 VAC |
| Pulse Rate Range | 20-250 BPM |
| Weight | 7.72 lbs |
| Temperature Range | 0 to 40 °C |
| Width | 8.7 in |
Medtronic Respiratory & Monitoring Solutions is recalling the battery packs due to a manufacturing defect that causes an increase in temperature within battery that may cause a fire in the system monitor.
