Stryker - CHG Spirit Select
The Only Truly Low, Acute Care Hospital BedSpirit Select was designed to make the lives of patients and healthcare workers safer and easier. This revolutionary hospital bed addresses the needs of a wide range of hospital settings including regular patient rooms in med-surg. Spirit Select is loaded with regular hospital bed features, and it has the ability to go lower to the ground than any other hospital bed on the market. All patients have varying needs that change constantly. Shorter, frail, elderly, and post-surgery patients benefit from the safety of a bed that goes 10" low. While taller more active patients will enjoy Spirit Select's infinite height adjustments. Spirit Select is the ideal hospital bed for pediatric patients.
FORUMSView All (5)
0Repliesa year ago | service manual need a service manual Equipment: Stryker - CHG Spirit Select Reply |
1Reply3 years ago | Scale zeroing Bed does not zero. It says bed must be level to zero . It level but wont zero ?Reply |
2Replies8 years ago | Head won't go down Head won't go down. all other functions work fine. Is there any tricks or some type of reset? Reply |
SERVICE COMPANIESView All Bed Companies
VIDEOS
[list] [*] Bed Exit Alarm - Numerous auto-arm alarm and volumes settings [*] Assistive Side-rails - Molded side-rails have an assistive design which helps patients to enter and exit bed safely [*] Multi-Zone Under-bed Obstruction Sensor - Instantly detects an obstruction and prevents bed from lowering until the obstruction is removed [*] Patient Lockouts - Any and all patient comfort controls can be locked to restrict patient use [*] Built-in Scale - Accurate to within 1% of a patients true weight [*] Weight Change Alarm - Set a Weight Change Alarm to notify staff when your patients weight goes below or above set parameters [*] On-Board Battery Back-Up System - Battery operates all bed functions nd immediately engages [/list]
Height | 10 in low hight |
