GE HealthCare - Critikon Dinamap 400 V2 Pro
Redesigned for quality-driven healthcare professionals who demand proven world-class technology in every parameterRedesigned for quality-driven healthcare professionals who demand proven world-class technology in every parameter, the GE Medical DINAMAP Pro 400 V2 brings together proven DINAMAP algorithms in a monitor with enhanced reliability features, and the durability you expect from a GE Dinamap Vital Signs Monitor.
With the GE DINAMAP Pro 400 V2 Monitor, you can take BP measurements that are fast, accurate and comfortable for your patients. And, you can obtain reliable temperature readings in seconds and get oxygen saturation readings using your choice of SpO2 solutions – the industry-leading Masimo® SET® (gold standard) or Nellcor® OxiMax.® So, you can spend less time checking vitals and more time on actual patient care.
FORUMSView All (6)
2Repliesa year ago | SPO2 with P00 Code When I plug in the cable it gives me a P00 Code. Same cable in a Dinamap Pro 1000 works fine. Any thoughts? Thank you. Equipment: GE Healthcare - Critikon Dinamap 400 V2 Pro Reply |
2Replies7 years ago | No startup with beeps We have a unit that when hitting the power button does the initial 5 beep sequence, then nothing appears. After about ten seconds, a high pitched beep starts. After an additional ten seconds a lower pitched loud beep starts. No error messages, just continual beeps. Does anyone know what is causing this? Not finding anything in the manual with this trouble. The unit does not do this on every startup. Reply |
0Replies8 years ago | Main Board Swap/ SPO2 settings Does anyone know how to change the settings for the SPO2 from Masimo to Nellcor. Swapped mainboard due to overpressure alarm, and now I'm getting SPO2 settings incorrect alarm? Reply |
- Measures NIBP
- Sp02, Temp & Heart Rate
- Pole Mount Included
- Includes New Battery, Sp02 Sensor, NIBP Hose, Oral Temp Sensor, 2 New Cuffs,
- Power Cord and Manual
- Completely Refurbished
- Biomedically Inspected
