GE HealthCare - Critikon Dinamap XL
by GE HealthCare
Designed for neonatal, pediatric and adult applications and features specific user selectable inflation pressures
The Critikon Dinamap XL Vital Signs Monitor is designed for neonatal, pediatric and adult applications and features specific user selectable inflation pressures. The vital signs monitor displays systolic and diastolic pressure, heart rate, temperature (predictive temperature) and tabular trends of data. Capable of running on AC or battery power, the Dinamap XL monitor is MRI compatible and performs automatic zero calibration. Memory storage covers 99 minutes almost 100 readings. Other features of the Critikon Dinamap XL Vital Signs Monitor include system malfunction message, auto deflation and stat mode operation.
[list]    [*]Less than 10 pounds.    [*]An optional printer can be purchased to make documentation easier.    [*]AC or battery power operation is designed so you won't have to worry about function or memory loss.    [*]Audible low-battery indicator so you won't run out of power unexpectedly.    [*]Optional spot check SpO2 - all designed to make your life easier.    [*]At its most basic, the DINAMAP XL Monitor offers the same reliability and performance you've come to expect from DINAMAP Monitors.    [/list]
