Ohio Medical - Air-Vac Infant Incubator
by Ohio Medical
This product is Discontinued
Designed to provide an intensive care transportation system for the premature and critically ill newborn.
Designed to provide an intensive care transportation system for the premature and critically ill newborn. provides regulated temperature, oxygen and humidity, along with visibility and emergency access during transport.            The Ohio Air Vac Transport Infant Incubator has a built-in humidifier, providing relative humidity of 40-60%. Filtration on this infant incubator is through0.5 micron filter pores, drawn from ambient air at 8-10 lpm. This infant incubator operates with a high temperature thermostat which limits temperature. The incubator model uses 90 deg F with 12 V D.C and 95 deg F with 24V DC supply at 35 deg F ambient.            Equipped with warning lights, the Ohio Air Vac Transport Incubator also has rotary temperature control with heater on and high temperature settings. Other indicators include charger on, full charge and low battery warning. This infant incubator uses a 5/16 th inch thick plexiglass oxygen hood for visibility. Its overall design includes a hinged front and top door, two spring loaded front portholes, and a rectangular head end port.
-GCHAIDEZ
9 years ago
12 volts baterry power pack
i need to buy a power pack for the incubator OMHEDA OHIO AIR VAC
-ao93
10 years ago
Air-Vac Transport Infant Incubator
I'll like to get the Operator's Manual and the Service Manual, too. Thanks
SERVICE COMPANIESView All Infant Incubators & Warmers Companies
[list]      [*] Designed to provide an intensive care transportation system for the premature and critically ill newborn.       [*] Provides regulated temperature, oxygen and humidity, along with visibility and emergency access during transport.       [/list]
Height15 in
Length 45 in
Weight46 lbs
Width19.5 in
