Fluke Biomedical - 52 Series
by Fluke Biomedical
The Fluke 50 Series II contact thermometers offer fast response and laboratory accuracy (0.05% + 0.3°C) in a rugged, handheld test tool. Take contact temperature for checking motors, insulation, breakers, pipes, corroded connections, liquids, and wires with industrial standard J, K, T, E, N, R, and S type thermocouple (temperature sensors).
2RepliesTue Feb 24 2015 | Fluke 52 User's Manual I have an older Fluke 52 K/J thermometer (not a Series II) without a user's manual and I cannot figure out how to utilize the min/max/avg feature. If you have a manual or know the procedure please enlighten me. I've located the service manual but it merely refers one to the user's manual for operation. Reply |
[list] [*] Relative time clock on MIN, MAX, and AVG provides a time reference for major events [*]Electronic Offset function allows compensation of thermocouple errors to maximize overall accuracy [*]Measures J, K, T, and E-types of thermocouples [*]Readout in ºC, ºF, or Kelvin (K) [*]Splash and dust resistant case protected by impact absorbing holster [*]User-friendly front panel is easy to set up and operate [*]Sleep mode increases battery life; typical 1000-hour battery life [*]Battery door allows easy battery replacement without breaking the calibration seal [*]Optional ToolPak accessory allows the thermometer to hang from any metal object (with the rare earth magnet) or secure around a pipe (with hook-and-loop straps) for hands-free operation. [/list]
| Height | 38 mm |
| Length | 173 mm |
| Weight | 400 g |
| Width | 86 mm |
Temperature scale: ITS-90 Applicable standards: NIST-175 Display Resolution: 0.1 °C, 0.1 K =1000
