Toshiba - Aquilion Lightning / RXL CT
by Toshiba
Aquilion / RXL is a whole-body multislice helical CT system with a Quantum detector capable of generating 32 slices per rotation using the coneXac reconstruction algorithm.
Utilizing new dose-reduction technologies such as AIDR 3D (Adaptive Iterative Dose Reduction) and Active Collimator, the system substantially reduces the patient exposure dose and improves image quality. The new generation console unit and SURETechnologies application software further improve throughput, reducing the time required for diagnosis.
-Nana B
2 years ago
Service manual
Pls can some one assist me with the service manual for Toshiba Aquilion lighting CT scanner for a fee. Its very urgentReply
-MOHAMEDBIOMED
5 years ago
service manual
we need service of toshiba ct 16 Reply
SERVICE COMPANIESView All PET/CT Scanner Companies
LOW-DOSE TECHNOLOGIES
  • Aquilion / RXL incorporates Toshiba's latest technologies for the reduction of exposure dose while maintaining high image quality.
LIGHTNING SPEED
  • The new console enables significant improvements in workflow, with faster reconstruction, automated processing, and remote access capabilities.
  • Aquilion / RXL accelerates the process of providing the information required for making the best treatment decisions throughout the workflow.
  • With a reconstruction speed of up to 28 images per second (16 images per second for standard configuration), all the images are available in a flash, even when Toshiba's unique 0.5 mm slice thickness is used.
AIDR 3D (Adaptive Iterative Dose Reduction 3D)
  • AIDR 3D is a sophisticated algorithm that has been designed to work in both the raw data and reconstruction domains. The collective AIDR 3D process results in robust noise reduction, which is essential for achieving ultra low-dose examinations in routine clinical imaging. This iterative algorithm is superior to non-iterative approaches in removing background noise while preserving diagnostic information.
MPR Image Generation- MultiView
  • MultiView automation saves time by reconstructing MPR images as a part of the exam protocol, reducing the number of images for initial review and/or printing
Automated Bone Removal
  • Aquilion / RXL incorporates automated bone removal algorithms to quickly and accurately segment bone in CT angiography examinations. In just a few seconds, high-quality angiographic images are available for diagnosis.
Lung volume analysis
  • Lung volume analysis* automatically identifies tissues in the lung fields with a CT number lower than the specified value (regions of pulmonary emphysema) by using volume data.
  • Volume, axial, sagittal and coronal images can be analyzed, and low attenuation areas can be displayed in each.
