Thermoline Scientific - B-Series
B-Class Bench Top AutoclavesThe The BD series autoclave is designed for economical efficiency but can still sterilize all your medical instruments and devices efficiently. The process firstly removes all air from the chamber then filling with steam which allows the steam to then penetrate and sterilize effectively. The sterilizing cycles have a unique drying process so the load is dried under vacuum and ensures the entire process complies with international standard procedures. The two models avaialble are 21.5L and a large 40.5 litre capacity chamber manufactured from 316 stainless steel, holding two stainless steel trays. Five pre-set cycle programs plus the BowieDick/Helix Test are available all selectable via the front controller.
[list] [*] Rectangle vessle with two trays [*] Five preset sterilization cycles [*] Adjustable cycle presets [*] Large LED display [*] Rapid heat up times [*] Printer fitted standard [*] Automatic safety door lock [*] Audible and visual alarms [/list]
