Berchtold - OPERON® D 850
by Berchtold
Surgical table
The OPERON D 850 is a multi-specialty surgical table that combines the ability to articulate high-weight capacities without sacrificing height requirements. Not only is it able to lift and articulate 1000 lbs, it is able to go lower than any other surgical table on the market at 22.6" yet is still able to rise to a maximum table-top height of 46.4". With its 17" longitudinal slide, carbon fiber table top, and integrated x-ray cassette channel, the OPERON D 850 provides an excellent platform for all types of imaging. Additionally, the removable head, back, and leg sections allow for customization of the table to fit the demands of all surgical procedures. Combined with a unique castor design and an optional Autodrive feature, the OPERON D 850 allows for easy movement from room to room if necessary. The OPERON D 850 has a backlit hand pendant with both pictures and text - making it very simple and safe to use especially during low-light procedures. The manual backup system allows for completion of surgical procedures should any problems arise. The backup hand pendant is identical to the main pendant and can be used in place of the main pendant in the event it is damaged. Additionally, the table padding combines memory foam, gel, and a four-way stretch fabric which helps ensure patient comfort and safety. The self-leveling floor locks also ensure that the surgical team is provided with a stable operating platform as well.
FORUMSView All (11)
-Hotsteam
Thu Oct 23 2025
Kidney elevator cylinders not in sync/uneven. How to adjust?
Cylinders not in sync/uneven. How to adjust?
-Fraza44
Tue Jan 24 2023
Operon D850 InstaDrive 5th Wheel Assembly
Anyone have any info on obtaining the 5th Wheel assembly for D850 better known as InstaDrive. I'm looking for a source other than manufacture since their parts are super expensive. I'm just looking for the wheel assembly with motor and hydraulics not the electronics associated with the system. Also is there a document which specifically covers the InstaDrive system because service manual leave allot to be desired. Any input would be appreciated.Reply
5
-Fraza44
Wed Nov 30 2022
Operon D850 Service Software
Is it possible at all to get the Service Software for the D850 these days? I had to replace sensor which appears to need calibration and from the service manual, I think I will need the service software for sure.Reply
VIDEOS
  • 1000 lbs of lift and articulation throughout entire range of motion
  • 450 kg of lift and articulation throughout entire range of motion
  • Greatest vertical range on market: 578 mm (lowest) to 1179 mm (highest)
  • X-ray cassette channel: eliminates x-ray tops while maximizing patient safety and user convenience
  • Carbon fiber tabletop construction: improved image clarity while minimizing exposure to patients and OR staff
  • 420 mm longitudinal slide: superior C-arm coverage without repositioning or reversing the patient
  • Imaging window: generous 535 mm wide tabletop allows for maximum imaging capabilities
  • Intuitive, ergonomically-designed hand pendant with back-lit keypad for precise patient positioning
  • InstaDrive™: Self-propelled drive system that assists in moving Operon D 850 within the surgical suite or from room to room
  • Special positioning for cardiac and/or neurosurgery
  • A full line of compatible accessories to customize your table
Patient Weight Capacity1000 lbs
  • 567 kg for normal orientation
  • 227 kg for reverse orientation
  • Height adjustable (without pad): 575–1180 mm
  • Longitudinal slide: 430 mm 1, 330 mm
  • trendelenburg /reverse Trendelenburg: 30°/31°
  • Tilt Left/ right: +20°/–20°
  • Backplate up/down: +90°/–45°
  • Leg plate up/down: +30°/–105°
  • Split leg plates up/down: +30°/–90°
  • Headrest up/down: +45°/–90°
  • Kidney elevator (optional); Lift to 75 mm
  • Flex (Auto position): 225°
  • Table length: 2124 mm
  • Tabletop width (inc. side rails): 534 mm (587 mm)
  • Image width: 465 mm
  • Manual backup system: integrated
  • Collision protection with all powered tabletop functions: integrated
  • Battery capacity 5-8 working days
  • Segments of OR tabletop up to 8
  • Tabletop material: Carbon fibre/pheno
  • Base material Reinforced fibre plastics/ABS polymer, stainless steel
