Alara - T110 CR
by Alara
Computed Radiography
The T-series offers Alara's proven, high-performance computed radiography technology - package for portability. This affordable, filmless, x-ray imaging solution provides lab-quality resolution and mobil-unit convenience for both medical, veterinary and non-medical applications. Whether you elect to use 8" x 10", 8" x 12' or 8" x 17" imaging plates capable of being scanned at resolutions of 150, 300 or 600 dpi, the T-series defines the standard in cost-effective radiography.
FORUMSView All (8)
-MariaLya
Tue Sep 26 2023
Imagen plates
Hi I want yo know if you sell image plate 8x17” for Alara t110 Thanks for you collaboration Maria Ordóñez Bogotá Colombia 57 - 3134377367
Equipment: Alara - T110 CR
-Lakeviewfootcare
Fri Mar 18 2022
Need plates and cassettes
Need plates and cassettes that fit this Crystal view t110 machine. looks like it takes 8 x10 8 x 12 and 8 x 17. This would be for a foot so 8x12 would work and if you can load 2 plates in one cassette that would work.Reply
-love4fun.kz_6180
Sat Jul 03 2021
Crystal view t110
How does this device work, what software and drivers do you need for it?Reply
  • 38 x 43cm or 30 x 38cm images for large radiographs. Expose two small plates at once in a large cassette then the two resultant images will be combined by automatic image stitching software into one seamless image.
  • Imaging Plates: 20 x 25cm, 20 x 30cm (standard) and 20 x 43cm
  • Dental, Intraoral Imaging Plates: Size 0 (22 x 35mm), Size 2 (21 x 41mm) and Size 4 (57 x 76mm)
Weight35 lbs
  • Dynamic range: 4.5 orders of magnitude
  • Signal-to-noise ratio: > 100:1
  • Resolution: >4 lp/mm (image plate limited), >10 lp/mm (scanner/technique limited)
  • Mains power: auto-sensing, auto-switching 100-240 VAC, 50/60 Hz
