KLS Martin - MY 60
by KLS Martin
The MY 60 is a compact, microprocessor-controlled, continuous-wave (cw) solid-state laser with a wavelength of 1,064 nm.
The MY 60 is a compact, microprocessor-controlled, continuous-wave (cw) solid-state laser with a wavelength of 1,064 nm.                    Thanks to its outstanding beam quality, the MY 60 enables you to work with extremely thin laser fibers.                    The reliable stability of performance - including the low power range - is an essential feature for controlled application of laser energy, especially where intraluminal and microsurgical indications are concerned.                    Thanks to a well-conceived set of technical features down to the detail, the MY 60 offers maximum safety and high user convenience.
-Moutaz
Wed Mar 04 2015
MY 60 surgical laser system
Dear pal
I need service manual for KLS MARTIN model MY 60
Best Regards
Moutaz
[list]  [*] The laser head and supply unit have been separated for the first time.  [*] Advanced solid-state laser technology with solid quartz cavity.  [*] Top irradiation quality – in addition to 600-µm and 400-µm fibers, super-thin 300-µm fibers are available for superior power density across the entire power rang.  [*] Cross-system use due to SMA-905 fiber connection.  [*] Multiple protection of SMA fiber connector and the focusing lenses by heat sensor, integrated protective glass and protective cover.  [*] Excellent power stability over the whole power range thanks to online power control.  [*] Integration of optomechanical components into a rugged, torsionally rigid, hermetically sealed laser block ensures that no user readjustments are necessary and permanent availability of the laser.  [*] A highly sophisticated design shows in utmost user-friendliness and easiness of use, just a few buttons give the user full control over a powerful and intelligent device.  [*] Special function display (total energy applied, stop watch and pulse counter).  [*] High level of operating and functional safety with microprocessor-controlled multiple monitoring of all operating functions.  [*] The electronically controlled coupling-in system guarantees troublefree laser transmission through the fiber.  [/list]
