B. Braun - Outlook 100ES
B. Braun smart pumps safe, reliable & easy to useDesigned to help prevent IV medication administration errors, the Outlook® 100ES Safety Infusion System features a large color display and extensive customizable drug library (watch video) that allows you to configure the pump to match your clinical practice. The Outlook 100ES is a logical choice for hospitals of any size who need a safe, reliable and easy to use infusion pump.
FORUMSView All (5)
0Replies6 years ago | Should We Invest or not? My company is in need of possibly replacing our Infusion Pumps across the network. We recently had a Fresenius Rep come in and give a demo. We currently are using B/Braun Outlook ES pumps and I personally love them. What is the general opinion of the Fresenius Agilia Pumps? Reply |
1Reply6 years ago | kit de infusion buenos dias, por favor me regalan cotización con foto del kit de infusión de esta bomba. gracias.Reply |
1Reply7 years ago | Has anyone seen the 100ES lock up for no apparent reason? We have several 100ES in our L&D area and have an issue where they suddently stop working. They will display the word "ERROR" and then just freeze. If you remove the battery and restart them they work fine. The issue appears to come and go and only affects units in the L&D area. We have checked our networking configuration and see no errors. We have swapped out the machines, Braun has looked at them and we have no answers. Anyone have any suggestions for troubleshooting or has seen this situation and has any insights or guidance? Reply |
[list] [*] Promotes patient safety by helping to avoid accidental under- or overdosing using audible and visual alerts for soft/hard dose limits. [*] Provides the ability to customize up to 300 drugs and 15 care areas to match your drug formulary, using the expanded DoseGuard™ drug library. [*] Provides reliable operation and accuracy using a proven delivery mechanism. [*] Provides comprehensive “at-a-glance” viewing of infusion status on a large color screen. [*] Promotes quick and easy drug selection using an active alphabetic drug library matrix. [*] Promotes safer and more confident programming with color-coded key pad and audible key clicks. [*] Real time display of dose limit values during infusion for titration safety [*] Active alphabetic matrix for quick and easy drug selection [*] Proven delivery mechanism provides reliable and accurate operation [*] Air trapping cassette eliminates nuisance alarms [*] Enhanced battery life [/list]
Height | 4.5 in |
Length | 8.75 in |
Width | 12 in |
Power: 120 VAC, 3 amp, 60 Hz Battery: 12V Sealed lead-acid battery
