Spacelabs - BLEASE 700 Series
Blease700 ventilators provide the performance users need in the OR.
Users can choose the ventilator configuration and the way they interact with the ventilator. A range of ventilation modes and waveform displays are available, enabling users to match their ventilator to their patient’s changing requirements. Users can choose from three models to match their precise needs.
FORUMSView All (14)
1Reply4 years ago | No enciende, cuando se enciende suenan las bocinas y se apaga Alguien sabra como solucionar el problema de encendidoReply |
2Replies6 years ago | Blease 700 Ventilator, does not sense Oxygen. I was repairing 06 ventilators ( Blease spacelab 700 series), 05 repaired successfully, last one ventilator does not sense oxygen, replaces oxygen sensor, Oxygen Board (PCB) but still does not sense oxygen, if Oxygen sensor removed it given Err Oxygen.. when connected Oxygen sensor it shows 0.0 with Oxygen low error...looking for service manual or a good advise from experts. Reply |
1Reply6 years ago | 700 series ventilator low exygen error Blease spaceblabs 700 Ventilator oxygen low, error, checked and replaced new oxygen sensor with old one, still error low oxygen, replaced sensor cable, then replaced PCB board where oxygen sensor cable is connect, at back of ventilator, still same error,, oxygen showing 0.0 and error say OXYGEN Low ...looking some expert tips to solve this problem (when cable is disconnected from oxygen sensor then on display show Oxygen "Err." if cable is connected it displays 0.0 and at top shows oxygen Low) ..if some one help plzReply |
- Volume Control, Precision Pressure Control Ventilation (PPCV), and SIMV with Pressure Support. PPCV can enhance the performance, safety and precision of the ventilation by actively controlling flow into and out of the ventilation drive system throughout the entire respiratory cycle.
- Pressure and Flow waveforms are clearly visualized on the 8.4” monochrome display.
