Carestream - CS2200
by Carestream
CS 2200 System
The CS 2200 Intraoral X-Ray System maximizes your diagnostic abilities and improves your workflow. Featuring an intuitive and user-friendly design, the unit’s very high-frequency (DC) x-ray generator ensures superior image quality and reproducibility, with improved safety conditions. What’s more, the unit’s new timer is a model of simplicity—further ensuring quick, safe and simple image acquisition.
FORUMSView All (5)
-drhempleman_8343
2 years ago
Error E 01 how to fix it
How to fix this? Reply
-Hector tecnico
6 years ago
Alguien sabe como solucionar el problema de error 13?
Alguien sabe como solucionar el problema de error 13?Reply
-BernieBoy
6 years ago
Service technician
Hi,
Can someone tell me if it is possible to fix CS2200 scisor arm that drifting.
Carestream recommand to replace with new generation arm, but i think it should be possible to replace the gas sping inside?
Thank you
bernard.harvey@videotron.ca
Optimize Diagnoses
Versatile Design
Maximum Image Quality
Reduced Radiation Dose
Usability at Its Best
X-ray TypeDigital
X-Ray Generator: Very High-Frequency DC (300 kHz)
Tube Voltage:60 kV, 70kV
Tube Current: 7 mA (film) - 4 mA (digital)
Power Supply:100-110-130 V / 60 Hz - 230-240 V / 50 Hz
Current: 12 A (100 - 110-130 V) -5 A (230 - 240 V)
Equipment Certification: UL - C/CE
Focal Spot:0.7 mm
Focal Length:8 in
Dimensions of Wall Mount:20.2 in (L) x 7.5 in (H) x 4.3 in (W)
Mounting OptionsWall (horizontal right and left, vertical), ceiling, mobile, floor
Arm Length Options: 67 in, 74 in, 81 in
