Spacelabs - Blease 900 Series
The Blease900 series of ventilators offer all of the features of the Blease700 series, plus a 8.4 full color display.The Blease900 series of ventilators offer all of the features of the Blease700 series, plus a 8.4” full color display. In addition, Advanced Pressure Support™ Ventilation determines flow and the end of inspiration based on your patient’s breathing rather than fixed time cycling. Patient effort is indicated by a marker on the screen. As with the Blease700 series ventilators, you can be assured of accurate control in all modes using dynamic compliance and fresh gas flow compensation plus active control of the inspiratory and expiratory flow valves. Ventilation requires monitoring to evaluate the effectiveness of therapy and to track changes in your patient. This information helps guide your adjustments according to each patient’s response. The Blease900 series provides Pressure/Volume and Flow/Volume loops which you can view, save and review for comparison.
FORUMSView All (10)
3Replies10 months ago | spacelabs healthcare anesthesia machine technical manual I urgently require the technical manual of the anesthesia machine. I would be very grateful if you help me on the matter. Thank you! Equipment: Spacelabs healthcare serie 900 Reply |
0Repliesa year ago | Please help calibrate CALBK |
1Replya year ago | Please help calibrate CALBK Good afternoon, a tragedy happened, I accidentally made FRU default settings and all the settings of the pneumatic unit disappeared.I can't calibrate the Block And Pressure Zeros item, it's just a countdown and a Failed Test-Discarded error, and I don't know what to do or open / close to pass this calibration, I beg if someone knows how to do this calibration write me Dlinniyalex@gmail.com |
[list] [*] Touchscreen technology [*] Active proportional exhalation valve [*] Rapid leak and compliance testing [*] Minimal maintenance [/list]
